My 2015 Pro-4X with Navigation seems to work OK most of the time...
Google, Pandora, iHeartRadio work as expected. The Google Search is often easier to use than the built in navigation voice recognition.
Facebook only works for events and posting locations. Sort of useless for any incoming messages, which is what I really care about.
Although I have TripAdvisor enabled, I have never used it.
My biggest gripe it that is occasionally just loses connection, and nothing works. Have to delete and re-pair the phone to get it all back again. I realize there is a lot going on communication-wise, but it should be more stable than it is. I'm sure the lawyers are as much to blame as the programmers...
is there a way to bypass the lockout, i know i was able to bypass my old pioneer hu with a clever you grounding loop switch that you could make or buy off ebay.
I am working on that one... Apparently the 'motion sensing' is pulses applied to the back of the radio. (I assume from a sensor somewhere in the drivetrain)... I am working on a circuit that will simulate the pulses at a slow enough speed to fool the system into working while moving...
Probably going to be mid-June before I can devote any real time to it. Will post a circuit and build thread here when it is ready.
