1 - 20 of 20 Posts
Hi all, hope this is the right forum, and apologies on the long post.
I am looking for a very specific model of Frontier. I want a crew cab, 4wd, manual transmission, long bed. By long bed, I mean 6'+, I don't know if there are some models that are not quite 6' so wanted to make that clear (6' is important because I will put a camper shell on it and sometimes sleep in the back, and I am 5'9" ;)).
I know that they currently make one in the SE model (and in fact, AFAIK, it's the only current truck by any manufacturer that fits this bill). But I am not sure I can afford a new truck. So I am wondering what years this truck was made, what models, etc. For ex, I have seen older XE's that look like they may be what I am seeking, but I am not sure. I also think I have seen some beds listed as 5.75', which is close but would be just a little short (and I don't know if that was considered the "long bed" at some point).
Also, if anyone has any advice on how to go about finding a used truck that fits this criteria (search terms, places to search, etc), I'm all ears.
Thanks!
2nd generation nissan trucks are from 2005 and up
yea your only choice in 2nd gen frontiers (2005+ models = "2nd gen") is a '07+ CC long bed SE manual, you can get it in 2 or 4wd depending on preference. in the first gens (1999-2004) i can't specifically remember ever seeing a CC long bed manual but they probably did make some. i may be wrong, just not something i've ever seen stated one way or the other.
They also made the 1st gen (i think 2003+) in CC long bed with the 5 speed manual.
I am thoroughly confused. For ex., I search and find things like this: 2003 Nissan Frontier XE Crew Cab 4x4 which says "long bed" but some of the the pictures make the bed look shorter than 6'. I realize that is an automatic, just using it as an example.
The transmission thing is the one negotiable aspect (though I really want to stick with a manual, pun intended), but I'm really looking for 4wd, crew cab long bed.
yep 2003 and 2004 I know for sure came in CC LB 4WD 5SP. I have an 03 but it's auto. my trim level is XE and I know they came in the supercharged trim also I test drove a 5sp but went with the auto. Look at the first gens from 2002 to 2004 and you will find what you're looking for. If you will be carrying a camper then don't budge on the 5sp. These things don't have alot of power
I believe it's actually 74". But I am positive it's no shorter than 72"....O hell let me go measure it BRB
yep 74" without the bedliner. I just measured it so no more guessing...lol
i believe gen2 beds are 72" exactly iirc... not sure why the change but i think that's the way it is
If you can swing a 2007 or newer that would probably be best for towing a camper. Nothing like an extra 60hp to get you over the hump...lol
otherwise you can find a 1st gen for fairly cheap
Discussion Starter · #16 ·
Not really planning on towing a camper. Though certainly would prefer a truck with some power! Used to own a 91 Nissan King Cab Pickup, and that little 4 cylinder engine, though it ran well, was a dog on the Colorado mountain roads that I drive on!
I run a VG30e...its a dog. VG33e isnt much better.
oops my bad OP says camper shell not camper. you'll be stoked with a first gen they rock!
1 - 20 of 20 Posts
