Hey there,
Was hoping someone could point me in some direction. I've got a 2013 Pro-4X (6-cyl) manual transmission. I've got this subtle sound the seems to "turn on" at exactly 2250 RPM. The best I can describe it is it either sounds like a faint exhaust leak, or like a fan is running and something hitting the blades. It's very faint but over time it's starting to irritate me.
So I was wondering if something "turns on" at that RPM speed, like a fan or something. Here are some additional observations.
* It happens in 1, 2, 3 gears, can't tell if it does in 4, 5, or 6 because the cabin is too loud at that point.
* It does *not* happen if I just rev the engine up to that RPM speed with the clutch disengaged. Only happens if the truck is moving. Sounds goes away when I let off the gas. Sound persists if I keep a constant speed around that RPM.
* It does not happen when it's cold. Takes a few miles before it starts.
* Like I said it's very soft, if I roll down the windows and stick my head outside I can't seem to hear it. I can't tell if the sound goes away as the RPMs climb or if I just can't hear it over the engine noise.
* It sounds like it "turns on" all of sudden. It's not a gradual build-up.
* When I start the truck, the cooling fan starts at full blast and then slowly settles down. I've heard that's a faulty fan clutch. Wondering if that's normal or related or another issue.
Any ideas?
Any ideas?
