1 - 3 of 3 Posts
So i have a 98 4cyl 2wd 5spd and i want to improve the height and look of the truck but i dont know what size tires to get or what my truck can handle. Its bone stock and when going up long hills i feel the sluggishness so im afraid if i put 33s on that hoe they will be too heavy. Does anyone know of a set of tire that will increase height and give it a meaner stance without sacrificing drivability? Or does anyone know of engine mods that will give my little 4banger a bit more cojones?
Sent from my iPhone using Tapatalk Pro
Taller tires will dog your 2.4 liter 4-banger down. If going w/ taller tires then regearing the rear diff to an even shorter ring/pinion is hopefully/ideally an option. Though, not sure what gears (if any) are available.
What is your stock size and what size tire are you running right now.
The 2wd came with the 195/75/14, about 25.5" in diameter. You are limited to the 14" rims. Biggest you can go is either a 205/75/14 at 26.1" or a 215/70/14, 25.9". Neither will effect your performance too much.
THe SE came with 215/65/15 which is about 26" in diameter. The sky is the limit on what size tire you can run on a 15" rim. I would personally bump the aspect ratio one up to make for a taller tire and call it good: 215/70/15, 26.9. 225/70/15 would be the next size up at 27.4, that would be a big bump. I would not go anything bigger.
You might find that someone already put bigger tires on your truck. That is why it feels like a dog. Seeing that stock is about 26, if you put 33s you'll have a heck of a time taking off from a dead stop never mind any hills.
1 - 3 of 3 Posts
