It has a 21.1 gallon fuel tank.
It's 21.125 = 21 1/8If that's the case, my gas gauge must be malfunctioning then. The gas light comes on around 25 miles on the "dte" Thanks for the quick replies.
The pump is cooled by fuel flowing through it. Also, there are baffles to prevent fuel from sloshing away from pickup.It has been stated that driving the tank extremely low isn't good for the fuel pump. Since it's located in the tank the liquid helps to keep it cool.
That is only part of the equation. The flow itself can cause heat due to the velocity. The fuel around the pump helps in addition to the flow.The pump is cooled by fuel flowing through it. Also, there are baffles to prevent fuel from sloshing away from pickup.
Take a look at the schematic for the fuel tank. The pump is at the top of the tank. I know this because I replaced my fuel sending unit. Pump is almost never immersed fully in fuel.That is only part of the equation. The flow itself can cause heat due to the velocity. The fuel around the pump helps in addition to the flow.
The general rule of thumb is that you should not let your tank go below 1/4 for a number of reasons ranging from safety of the vehicle to your own personal safety.
In this application, pressure would cause heat increase, not velocity. In the application of a typical fuel pump/injector system, there isn't sufficient pressure to have a notable increase. There's only enough pressure to cope with gasoline's volatility, and serve the needs of the injectors.The flow itself can cause heat due to the velocity.
Well, that's sure better than the idea that if your lite comes on too many times, the fuel pump self-destructs.:rofl:Yea, I heard if your lite comes on too many times it voids your warranty!
...nor the world come to an end, giggle.Thats assuming of course your pump doesnt
burn up and your truck doesnt explode.:laugh:
not one bit of truth in that.Yea, I heard if your lite comes on too many times it voids your warranty!
