1 - 7 of 7 Posts
So, trying to figure out what rear axles I have in case I ever need to replace one. Here is the tricky part though, my M226 is not stock, I replaced the c200k with it. I got in on ebay brand new. Here is all the info I have to determine what axles I need. I have pretty much determined by the date on the sticker and gear ratio that its out of a 2014 6M offroad or Pro4X. Looking on NissanPartsDeal.com nothing seems to match with those options. I dont think there are any S, SV models with lockers. I am assuming it has the left and right specific ones that are different lengths.
Frontier M226 5/20/2014
Gears - 3.69
E-Locker - yes
Sent from my VS990 using Tapatalk
Gone but not forgotten Member
I have an S model, MT,M226. I know if you have a factory e- locker you have to change one of the axles if you go to a "Trutrac".
Mine was an open differential and used the same axles it came with when I went "Trutrac".
I ordered my truck but I thought I could get e-locker as an option. Not sure because I did not want one.
Yeah,I think you are right if you have the locker?
Are you worried you might break an axle on the trail?
It does have a factory E-locker which makes me think it needs the different lenght axles.
I think it would be these
Sorry to threadjack but I have wondered if when you swap out the 200 for a m226 do you have to change the drivehaft or anything else? I have googled and searched here but never found an answer.
Sent from my SM-G920W8 using Tapatalk
holy **** thats expensive. i picked my last one up for 150$ shipped.
depends on your model. some have a 4 bolt and some i think have 6? idk i have only ever had 4.
Depends what the M226 is coming out of. If your flange is 4 bolts and the m226 has a 4 bolt flange then you are good. The m226 does have different abs sensors and they are expensive, mine had them so I got lucky.
1 - 7 of 7 Posts
