Hey everyone, I hopped on here to try and identify this part on my 2004 Frontier. Pics attached. I'm looking at the metal weave cylinder around one of the exhaust pipes. This cylinder is on the exhaust pipe coming off the right side of the V6 engine before it merges into the other exhaust pipe and into the catalytic converter. In the pic, you can see there are two loose rings on either side. The rings are clanking whenever the engine is running, but don't appear to have actually been doing much in the first place. I believe this is just a heat shield and the rings are clamps, but not positive. If it is a heat shield, I'm thinking of just using some high heat epoxy to reattached them. Thoughts?
