1 - 4 of 4 Posts
Has anyone ever looked at what other leaf packs from other vihicles are compatible with ours? I've seen the OME leafs, and the guys that did the Frontier/Xterra hybrid Leaf packs, but are there any off the shelf leaf packs that we could stick in our trucks to make the rear axle heavy duty and give it lift at the same time? I'm looking to get 4-5" back there.
Gone but not forgotten Member
Don't know what you mean by heavy duty axle.Changing the leaf pack has nothing to do with the axle.
The only way to get that much lift out of a spring pack and not be too stiff is a custom pack.It needs to be progressive, therefore a lot of leaves.Most are around ten.
You maybe be able to put together a leaf pack by mixing and matching different leaves but it would be a lot of testing and very time consuming.Call Deaver,tell them what you want is your best bet.
Give these guys a call, a good number of the X crew use them and they will build exactly what you want and will talk to you until they are sure they are making what you want.
Information Request
The PRG/Deaver race pack claims 2.5"-3" lift.
With the adjustable shackles you can get your 4" of lift.
I have a set of PRG/Deaver race pack springs.They were too light for my truck.
I want $550, pick up only.I am in Los Angeles.
1 - 4 of 4 Posts
