1 - 3 of 3 Posts
An intermittent buzzing and flashing right turn signal came on right after pulling out today. Both buzzing and flashing light stopped when I pulled off the road to check. Total time was about 10-15 sec or so from start of the warning(?) to the stop. The truck ran fine afterward. I'm not sure if I have a problem or not. Couldn't find anything with those symptoms in the manual, so suggestions much appreciated.
Background Info
Tire pressure, engine temp, and fluid levels not a problem. I recently had some work done: front end (sway bar endlinks and upper control arms replaced) and exhaust (muffler and tailpipe replaced). Has a new K&N air filter.
There was another thread a few years back about a strange warning (intermittent buzzing) with no follow up solutions.
StHunt
2004 Frontier XE, 4x4, Crew Cab
1 - 3 of 3 Posts
