Hi - this is for anyone that has a shop manual - was replacing the air filter and noticed hose on right side/inboard side towards firewall that simply ends at the air box - it is even zip tied to it.
at the other end it appears to be attached to the ?Transfercase/Axle? on the front left axle....
Apologies to the mechanics out there and my lack of knowledge and nomencalture - First 4X4 Truck. First Truck and I'll be honest - don't know Shiite about trucks, but learning.
A pic would be helpful and will post later if needed. A diagram from the service manual and description would be appreciated.
Thanks in advance to all of you! Stay safe!
the end by the air box does not connect to anything, this is normal. enjoy you truck!
Discussion Starter #5
AH did not see your reply Mss3y - Thank you - figured it was a breather of some sort - Thank you all!
Question answered!
That's why it makes sense to do an extension hose on the rear diff -- so it can breathe and not suck in dirt or water.
