Jordo what lights do you have on your truck and are they a full conversion kit with seperate lights or did it all come together? Cost? thanks
3 can get from prg. the titan mid travel is literally a mid travel kit for the titan that will work on a frontier designed by mazzula that you can get 17in out of but i've heard that many people are having some binding issues at 15in with the ball joint. mustards builder will be putting out a kit that from what he says should be the same if not lower in price and have more travel with no bindingStage 1: Coilovers - 8" of travel
Stage 2: Extended Coilovers and aftermarket control arms - 9" of travel
Stage 3: Titan Swap with extended coilovers and aftermarket Titan arms - 12" of travel
Stage 4: Titan mid travel kit - 15" of travel.
So what is the Titan mid travel kit and where can you get it and is stage 3 the prg kit that has the titan lowers with prg uppers?
Greg (PRG) sells the Titan Mid Travel set up; PRG Titan Mid-Travel. Although, I am pretty sure the pricing has changed as material costs have gone up quite a bit.So what is the Titan mid travel kit and where can you get it and is stage 3 the prg kit that has the titan lowers with prg uppers?
Yes, one in the same. I have been running it for about 2 years now and have been very happy with it.Hey Terribleone is that the kit that's on ur avatar.
In theory; assuming the kit is using stock pivot points you should be able to bolt up the arms. But it's not as simple as that; there is a lot of fabrication involved... things will definitely need to be cut and moved around in the engine bay.Another ? Does it mean that any titan mid travel/long travel kit fit the frontier.
