BACKSTORY
OK so many of you already know much of the backstory on my Frontier. Except for maybe the part where my neighbor put $50 into it, before quitting and giving it back.
One thing I never mentioned was that it was also blowing white smoke out of the exhaust. It didn't start doing this until the day after I got so frustrated that I revved the hell out of it in the driveway, before realizing that 4 qts of freshly changed oil had suddenly vanished without a trace. It never overheated though.
FRONTIER SYMPTOMS:
*Thick white smoke from exhaust. But only after 2-3 minutes at idle and only thick until operating temp is reached, after that the exhaust is still present, but barely visible. It's actually light gray at first, then turns white.
*Excess liquid draining from exhaust. To be expected from increased steam. Taste like water. Can't describe the smell. Slight fuel smell, but could be normal. Never stuck my nose in the exhaust before lol. And I have no idea what the sweet smell of burned coolant smells like, but I'm guessing I'd know it if I smelled it.
*Idles like $hit once it reaches temp. However, this is inconclusive since it idled like $hit long before blowing white smoke.
*No loss of coolant, no bubbles at temp, and no exhaust gases present (Fluid remained dark blue).
*No overheating
*Dipstick and oil cap show only fresh clean oil (no white)
*All plugs looked good except #2. It was actually drenched in fuel, oil, and coolant. However, I had a slight coolant leak from a hose under the intake manifold above the #2 well, and I had been priming the fuel pump and messing with that injector, so this could all be unrelated. I did clean the plug and fixed the leaking coolant hose. Later I pulled #2 again and it looked good.
*Compression 160 psi across all 6 cylinders
THE REAL PROBLEM
OK, so those of you who know the history of this truck are probably thinking no doubt, blown head gasket. In fact, I'd be lying if I said I didn't agree with you 100%. Given the issues and abuse (from my ignorance) that this truck has sustained I'm surprised the engine hasn't fallen out of the frame. But.... here's where things get interesting. My 95 Pathfinder, with the same engine, and absolutely no problems EVER... is now doing the exact same thing not two months after the Frontier began doing it. The same thick white smoke after 2-3 minutes at idle, and only until it reaches temp. The main differences between the two vehicles are 1. I never messed with anything on the Pathfinder 2. It has 0 blown head gasket symptoms outside of the four or five minutes of thick white smoke. It starts, idles, and runs flawlessly. The MIL has come on recently, but I've also been restoring it. It's pre-OBD2, so I can't plug my reader to it. In any case the light came on long after the white smoke started. 99% positive it's unrelated.
THE QUESTION
If someone told me I blew a head gasket in the Frontier they'd get no argument from me. If someone told me the head gasket was suddenly going in the Pathfinder due to old age, despite showing no other signs, I might buy into that. But... you tell me that two vehicles, with the same engine (VG33E engines at that), both blew head gaskets within two months of each other, and with neither vehicle showing any conclusive symptoms of a bad HG aside from the temporary white exhaust... highly unlikely. It is possible, but statistically improbable. So the million dollar question is... what else, outside of gaskets and seals, can cause thick white exhaust? If we were only talking about the Frontier I would say it could be 100 different things causing it, like the PCV or AIC valve I put on it just before it started doing it, but with the untouched Pathfinder as well... it's got to be something simple. Like a sticking injector or somethings.
NOTE: I brought this question in here is because I inputted every permutation of my question that I could think of into Google and the only results I get back are The 8 signs of a blown head gasket. At some point you just get frustrated and say I know what the damn symptoms of a blown HG are, now tell me what else causes white smoke! I'm sure we've all been there more than once
Appreciate any insights you may have.
https://youtu.be/FeZm4Wo7SXw
Sorry about the video being at an angle. IPhone does strange things in the cold. I'll get a better one on here tomorrow.
FRONTIER SYMPTOMS:
*No overheating
THE REAL PROBLEM
THE QUESTION
