hey, i had a 1708 fault and grabbed a service manual that I found for free.
C1708 [NO - DATA] - FL Data from FL transmitter cannot be received.
C1709 [NO - DATA] - FR Data from FR transmitter cannot be received.
C1710 [NO - DATA] - RR Data from RR transmitter cannot be received.
C1711 [NO - DATA] - RL Data from RL transmitter cannot be received.
In other words; problem with your tire pressure monitor.
No biggy, your truck is not about to implode.
Here are the steps to resolution; Basically.. you need their computer in order to do it all.. but the basics are; check your tire pressure, check the reciever connector, replace sensor.
DTC CONFIRMATION PROCEDURE
1.ID REGISTRATION AND VEHICLE DRIVING
1. Carry out ID registration of all transmitters.
2. Drive at a speed of 40 km/h (25 MPH) or more for 3 minutes, and then drive the vehicle at any speed for
10 minutes.
3. Check all tire pressures with CONSULT-III within 5 minutes.
Does DATA MONITOR ITEM display tire pressure as normal without any warning lamp?
YES >> Inspection End.
NO >> Refer to WT-14, "Diagnosis Procedure".
Diagnosis Procedure INFOID:0000000004055218
MALFUNCTION CODE NO. 21, 22, 23 OR 24 (DTC C1708, C1709, C1710 OR C1711)
1.CHECK BCM
Drive for several minutes. Check all tire pressures with CONSULT-III.
Are all tire pressures displayed as 0 kPa?
YES >> GO TO 2
NO >> GO TO 3
2.CHECK TIRE PRESSURE RECEIVER CONNECTOR
Check tire pressure receiver connector for damage or loose connection.
Is tire pressure receiver connector damaged or loose?
YES >> Repair or replace tire pressure receiver connector.
NO >> Replace BCM, then GO TO 3. Refer to BCS-56, "Removal and Installation".
3.PERFORM ID REGISTRATION
Carry out ID registration of all transmitters. Refer to WT-6, "ID Registration Procedure".
Is there a tire that cannot register ID?
YES >> Replace malfunctioning transmitter, then GO TO 5. Refer to WT-48, "Transmitter (Pressure Sensor)".
NO >> GO TO 4
4.DRIVE VEHICLE
1. Drive at a speed of 40 km/h (25 MPH) or more for several minutes without stopping.
2. Check all tire pressures with CONSULT-III within 15 minutes after vehicle speed becomes 17 km/h (11
MPH).
DTC CONSULT-III DTC detecting condition
C1708 - C1711 DATA FROM TRANSMITTER NOT BEING RECEIVED
WT-15
< COMPONENT DIAGNOSIS >
C
D
F
G
H
I
J
K
L
M
A
B
WT
N
O
P
NO >> GO TO 5
5.ID REGISTRATION AND VEHICLE DRIVING
10 minutes.
NO >> Proceed to the inspection applicable to DTC.
Special Repair Requirement INFOID:0000000004055219
Perform preliminary check. Refer to WT-5, "Preliminary Check".
