200-300 miles after prg install I'm getting weird noises at random speeds from the front (driver's side).
Noise: clanking/chirping noise, depends on the speed faster or slower; does not depend on terrain.
Checked so far: PRG UCAs, coilovers
What do you guys think?
Bearing?
Hubs?
Brakes?
BTW it is 05 4x4 cc le 4.0L
Thanks
I don't know if this is your problem, but check your sway bar. My sway bar tends to squeak alot if I don't keep the bushings lubricated, and I'm too lazy to unbolt the brackets and use a proper grease to lubricate the bushings so I just use a spray lube (it gets rid of the squeak for a month)
maybe jack up the front and take the load off your fancy new coilovers and shake them vigorously side-to-side to check for play in the bushings? If you've already done that I got nothing.....unless the new UCA's have defective ball joints? Of course I guess in those situations the noise would only happen when you hit bumps. are you getting the noise just driving straight, or does it happen when you turn?
