1 - 3 of 3 Posts
*Brand New* WD SiliconEdge Blue SSC-D0128SC-2100 2.5" 128GB SATA II MLC Internal Solid State Drive (SSD) - OEM
Sequential Access - Read:Up to 250MB/s
Sequential Access - Write:Up to 170MB/s
Power Consumption (Active):2.0W (Read), 3.5W (Write)
Power Consumption (Idle):0.6W
Max Shock Resistance:1000G, Half-sine, 0.5 ms Duration, 50g Pk, MIL-STD-810F, Method 516.5, Procedure I
Max Vibration Resistance:16.3gRMS, MIL-STD-810F, Method 514.5, Procedure I, Category 24
Height:9.5mm
Features:Fast data transfer - Up to 250 MB/s read and up to 170 MB/s write transfer rates allow your system to run faster so you can work more efficiently. Advanced Wear-Leveling WD's wear-leveling algorithm uses a combination of dynamic and static wear-leveling that writes data evenly over the entire drive, preventing drive
$255.00 shipped
serious?
1 - 3 of 3 Posts
