Hi
I have a 2012 Frontier Pro 4X The truck has never been off road or in water.
The abs light came on soon I took it to the dealer. They replace the rear axle breather tube but said there was water in the rear end, and it need to be replaced. They asked if I had a boat and I told them NO. The said that the truck must have been in water, I told them never I bought it new. I had heard that if the breather tube was block this could cause condensation causing water to be trapped in the rear end, but the refuse to cover it under warranty and want $5000;00 to fix it the truck has 41000 Kms
Has any one had or heard of this happening
Thanks
I think it would be quite difficult to actually get water into the rear differential.
You didn't have trouble with the differential, correct, just with the ABS?
If so, I think I'd drain the rear differential and let the fluid settle, water - if present - should sink into a bottom layer. So what if you drain differential and refill with new gear oil, or I am I just being too simplistic?
They replaced the rear axle breather tube, eh?
That's odd, because the M226 doesn't have a breather tube, that's one of the first mods suggested on this forum. All it has is a small one way valve, and it has a habit of sealing itself shut, causing blown axle seals.
