washer fluid not spraying HELP
1927 Views 7 Replies 5 Participants Last post by  devious1
so im driving to work go to clean my window and no fluid will spray washer fluid tank is full not frozen. sounds like my washer pump isnt getting any power i cant hear it making any noise but my wipers still move. HELP PLESE
1 - 8 of 8 Posts
check to see if the sprayers are blocked or have debris in them?
do you know fuse location? pump doesnt seem to get power?
The pump probably went out. Are you under warranty?
replaced pump works great now thanks guys
Never heard of that one. I thought those were like the Energizer bunny.
Had mine go out in my old 97' rodeo. Just had lots of corrosion in the motor.. tore the motor apart and cleaned it up real good and it worked again... sucky thing to stop working though! Hadda' stop at ever freakin gas station.
1 - 8 of 8 Posts
