Vote For ClubFrontier Truck of the Year 2012
  • x_mods
    Votes: 20 32.8%
  • crewmaxxis
    Votes: 4 6.6%
  • frontyfan
    Votes: 8 13.1%
  • JeniorNV
    Votes: 7 11.5%
  • steedsta
    Votes: 0 0.0%
  • brokendiff
    Votes: 1 1.6%
  • BRUTAL
    Votes: 8 13.1%
  • bbaker06
    Votes: 1 1.6%
  • sudingusnavy
    Votes: 4 6.6%
  • 5speed_Frontier
    Votes: 1 1.6%
  • davidshourd
    Votes: 3 4.9%
  • Kamikaze
    Votes: 4 6.6%
  • Total voters
    61
  • Poll closed .
Let the voting begin for the 2012 ClubFrontier Truck of the Year!
Voting will end on January 1, 2013.
January 12 - x_mods
2010 PRO-4X 2WD CC
Interior: Black & Orange Wet Okole Seat Covers, Wheelskins Charcoal Steering Wheel Cover, DashMat Charcoal Dash Cover, Black WeatherTech Floor Liners, BlendMount for Bully Dog GT, ProSport Performance Vacuum Gauge, V-LEDs dome lights/map lights/footwell lights, PRO-4X 5 Switch Cluster, 5 OTRATTW Illuminated Rocker Switches, Stinger Voltmeter
Exterior: Smittybilt Hitch Shackle, Westin Side Steps, Truck Covers USA Retractable Bed Cover, Thule Rack (on the bed), V-LEDs LED, Red Mirror Turn Signal, xoskel light bar, EZDown Tail Gate Shock, Bosch Icon Wipers, Flat Black Nissan Logos, Full Ceramic Window Tint to ALL Glass, Orange Digital Camo Tailgate, Custom Orange PRO-2X Decals, 808UpFront Custom Front/Rear Burgers
Lighting: TRS FX-R 1.1 Projectors (Modded to come on with key fob), Gatling Gun Shrouds, Morimoto 5Five 55w Blasts, Philips D2S 85122+ Bulbs, TRS Mini H1 Foglights, Morimoto 3Five 35w Balasts, 3000k H1 HID Bulbs, x_mods Custom Rigid Roof Mount, Rigid SRCW 40" light bar (Roof), Rigid Dually Flood Pair (Mirrors), Rigid Dually Spot Pair (Bumper Mouth) ,Rigid Dually Spot Pair (Bumper Mouth) ,Rigid Dually Diffused Flood Pair (Rear Bumper)
Drivetrain: Radiator Cooler Bypass, Flex-a-Lite Transmission cooler, Filter Mag Transmission Magnet & Rear Differential Magnet
Suspension & Tires: Bilstein 5125 & 5100 Series Lift Shocks, ReadyLift 2.5" Lift, PRG 2" AAL PRG Adjustable Upper Control Arms (Orange), PRG Adjustable Sway Bar End Links, PRG Adjustable Shackles (Orange), PRG 2" Rear Lift Blocks (Orange), PRG SS Front Brake Lines, 4x4parts SS Rear Brake Lines, CST Lift Spindles, Sway Bar Delete, PRO-4X 16" Wheels (PlastiDipped), 285/75R16 Goodyear Wrangler Duratracs, High Polish .44 Magnum Valve Stem Caps, Painted Center Caps, 1" Rear Wheel Spacers (to match the CST lift), 4x4parts Poly Bushings, Power Slot Rotors, EBC Green Stuff Pads, 808UpFront Custom Wheel Badges (Orange), Painted Spline Lug Nuts (Orange)
Armor: SHROCKWORKS C200 Skid Plate (Orange), Painted Factory Tin Foil Skids (Orange), Orange Daystar Motocross Fork Guards
Performance: Injen Power Flow Cold Air Intake (Orange), Intake Manifold Spacer, Bully Dog Triple Dog GT, Optima Yellow Top, K&N Oil Filter, 2x Filter Mag Oil Filter Magnet, Royal Purple ALL the way around, 350z OEM T-stat, Stillen Light Weight Under Drive Pulley, Pulse Plugs Dynomax Cat Back (Black), Dynomax VT Muffler (Black), Custom Saikou Michi Oil Catch Can (Orange), Clutch Fan Delete, Dual 12" E-Fans
Audio: Pioneer AVH-P3200DVD Head Unit, Pioneer ND-BC4 Back-up Camera, Alpine PDX-5 Amplifier, 4x Polk Audio db5251 Component Speakers, Alpine R10 V2, SO Ported Box, Rockford Fosgate Wiring, Cobra WXSTII CB w/Firestik 4' Dual Trucker Antenna & Fold Over Mounts
February 12 - crewmaxxis
2005 Nissan Frontier Nismo, Storm grey
Drivetrain: Titan swap M205, stock rear m226 with e-locker
Suspension & Tires: Front: Calmini 5" DB lift, PRG Titan UCA, stock titan LCA, Tierod ext, Radflo 2.5", SS brake lines, stillen rotors, EBC greenstuff pads, bighorns 285's on stock 16" rims
Rear: AAL, 2" block, flip kit with beefy 5/8" u bolts, relocated 1/4" rear shock mounts
Exterior: Snugtop shell with integrated roof racks, Xoskel lopro roof mounted lightbar with 4 rectangular lights, Daytime Running Lamps in lower grill opening
Armor: stock nismo, calmini engine skid, Hefty gas tank, T-case skids and radiator
Interior: rearview camera mounted on tailgate center by handle; 3" screen in rear view mirror, rocker switches for lights on dash
Performance: KN drop in filter
Mods:de-badged rear tailgate
March 12 - frontyfan
7" lift front, 8" rear. Calmini lift, Titan swap, 2.5" extended length coilovers, PRG Titan UCAs, Alcan custom leaf packs, airflow snorkel, Volant CAI, 35s, LEER canopy, shrockworks bumpers and sliders, NXRocks skid plates, Ramsey 9500# winch, PIAAs, M226 w/ e-locker swap and more
April 12 - JeniorNV
2009 SE King Cab 4x4 6 speed
Suspension and Tires: OME 607 coils, Bilstein 5100 leveling struts, PRG Deaver 2" AALs, Bilstein 5125s, sway bar removed, Hankook Dynapro ATM LT265/75/16
Armor: Calmini rear bumper, custom sliders, Hefty Fabworks engine skid plate, Hefty Fabworks transfer case skid plate, Hefty Fabworks gas tank skid plate
Gears and Axles: Spartan rear locker
Exterior: Softopper, mud guards removed, front valence removed
Interior: Cobra CB radio
May 12 - steedsta
2005 Frontier Crew Cab LE 4x4 automatic 127k miles
Front Suspension: Titan LCA, PRG titan UCA powdercoated, PRG TRE, PRG Axles, Sway-A-Way External Reservoir Coilovers, Stainless Steel Brake Lines
Rear Suspension: RadFlo External Reservoir shocks, PRG Deaver 10 Pack Race Springs
Wheels & Tires: 17" Walker Evan Racing Street Beads Powdercoated Matte Black with Powdercoated Rings, 33" Nitto Terra Grappler
Exterior: Fiberwerx Front fenders, Tiregate Powdercoated to match suspension and wheel Rings, , Custom Front Grill, Custom Built, Not Bought Front Pre Runner Bumper, 3 Hella 4000 spot lights, 2 Euro beam 1 Pencil beam, removed running boards, tint all four corners
Interior: Kenwood Head Unit with Infinity Speakers
Performance: K&N Drop In Air Filter and home made under fender Intake tube to prevent water from getting in the air box
June 12 - brokendiff
Full titan front end swap, PRG UCA's, 2.5" SAW coilovers, 6" Pro Comp lift for Titan, 2.5" adapter/spacers on rear for Titan bolt pattern and width, 17" stock Titan rims painted rattle can black, 33" Pitbull growlers, CAI, TBS, JBA headers, 3" magnaflow exhaust, CPU reprogrammed by Jet chips, KC's w/ 130 watt bulbs, 22" vision X LED light bar. Iron Fist Offroad rear bumper
SEE POST NUMBER TWO FOR THE OTHER 6 TRUCKS
Discussion Starter #2 (Edited)
July 12 - BRUTAL
2005 NISMO 4X$
Front suspension: Prg Titan swapped with Titan M205 diff with 4.56gears. 4" lift
Rear suspension: Prg 10 pack springs and Adj shackles, Locked M226 w 4.56 gears
Wheels/Tires: OMF Nismo streetlocked wheels. BFG KM2 305/70/16
Armor: Front Shrock bumper, owner fabbed rear bumper with tire carrier. Trail gear weld on sliders. Shrock full skids.
Exhaust: Stainless headers and full owner fabbed stainless 2.5" dual into a Spin tech muffler with 3" out
Brakes: crossdrilled rotors and EBC Yellowstuff pads
Trans: Modded Valvebody, B&M cooler with fan and Amsoil tranny fluid
Lighting: HID projector headlights, and HID projector fogs, PIA and Bightassed LED offroad lights front, sides and rear.
Engine: ported heads, CP forged pistons 8.5-1 compression ratio, pahter billet rods, ARP head and main studs. Brian Crower stage II cams and hi rev springs, titanium retainers. power to 7000rpm. induction 550cc injectors and soon to be a 2.6 litre Kenne Bell Twin Screw super charger. custom setup looking for 15psi and 375-400RWHP. Tuned by ENGINE LOGICS w/Uprev software.
August 12 - bbaker06
2006 Super Black LE Crew Cab
Interior: Stock Le leather, oem Rockford system, cobra 29ltd cb radio, aftermarket auto shifter handle.
Exterior: xoskel light cage, oem roof rack, sunroof, blacked out grille, rattle can bedlined oem nerf bars and rear bumper plastics. Plastidip oem wheels black.
Drivetrain:all stock
Suspension & Tires: PRG 2" spacers + 4" CST spindles, ss extended brake lines(6"front), 1.5" blocks + prg aal + prg adj shackles, 5125 bilsteins (5" rear) removed mud flaps, Goodyear DuraTrac 285/70r17
Armor: Calmini front pre-runner bumper
Performance: Superchips Cortex Tuned. Knock-off Magnaflow muffler, throttle body mesh removed, throttle body coolant line bypass.
Gear and Other: stock utilitrack, oem sliding tool box, oem soft tonneau cover, homemade spare tire bed mount, Cobra CB radio.
September 12 - sudingusnavy
2011 PRO4X
TITAN SWAPPED!! PRG T-UCA, Titan LCA, PRG Axle shafts, PRG TR extensions, PRG S/T brake lines, Radflo 2.0 650 springs W/ 2 in. spacers, Deaver AAL,PGR shackles, Bilstein 5125 , kool vue CAI, Helix T/B spacer, Bullet performance exhaust, axle vent mod,trottle body cone removal mod, shrocks sliders,Titan diff cover w/ Rocky road diff skid plate, Hefty fab.winch bumper, custom 3 1/2in steel drive shaft, Falken A/T 285/75, Hefty fab. full skid plate set, Quadratech Q9000lb. winch, BAJARACKS roof rack, Vision LED strobe lights, Rigid Ind. LED fogs, Optima yellow top.
October 12 - 5speed_Frontier
2006 Frontier XE, King Cab, 4 cylinder, 5 speed manual
M226 Axle Swap w/ 4.56 gears/locker, Doug Thorley Long Tube Ceramic Coated Headers, 2.25" piping cat-back to Magnaflow muffler, Custom Cold Air Intake w/ Extended MAF wires, 2* Timing Advance, Exedy Clutch Kit, 16" Level 8 Strike 6 Wheels, 285/75R16 General Grabbers, CST Spindles, PRG Titan Swap w/ 2.5 Radflos w/ 500lb. Eibach springs, Steel Braided Brake Lines, Deaver AALs, Bilstein 5125s, Cobra CB in Center Console (with PA & Extended speaker), 3' Firestik Antenna, 5000k 55w DDM Tuning HIDs, hurst shift knob, weathertech floor liners, red underdash lighting, 35% Tint Front Door windows, and 20% visor tint.
November 12 - davidshourd
2007 6sp Nismo
Titan Swap, Sway-a-ways w/remote res. PRG Deaver leaf pack with 1.5" longer HD shackles, Hankook MT 285/75R16, Volant intake w/AirFlow Snork, Gibson Cat Back Exhaust, SuperChip, Otpima Red Top X2 dual battery with switch over, KMA front bumper, Custom Sliders, Custom skid plates, custom rear bumper with Tire carrier, Warn xd9000i hitch winch (front or back hook up)
December 12 - Kamikaze
05 Nismo CC 4X4
Interior: Wet okole seat covers, Panasonic deck and speakers, husky liners,CB,10" low pro sub.
Performance: Airflow snorkel, Red top optima, straight pipe, New Radiator, Green stuff brakes all the way around.
Everything else: Titan swapped with PRG Uppers,2.5 RF, PRG Extended half shafts,4 linked rear suspension, Tubed and bobbed bed,285/70/17 BFG All terrains, Herculined quarter panels and grill, Tinted windows,PR Tiregate, Shrock sliders,UWS Toolbox, 2" BL, 12000k Hid Halos,Defender RR, 4 Hellas. RLTW
Discussion Starter #3
All of the TOTY mod lists would not fit into one post, so I had to delete all other posts in the thread in order to split the pic/mod lists into two posts. All deleted posts are quoted below. Sorry for the inconvenience.
voted, i have to say Frontyfans truck is amazing. Cant wait till mine can be as sick as it. soon!
WOW! what a bunch of sweet trucks!
good line-up indeed. I went with Brutal - that thing is a beast and he is never done with it, always sharing the newest mods.
^If Brutal wins two years in a row they don't have to change the picture on the front page lol. Lots of great choices, i'm going to have to think on it for a few days!
I forgot he won last year, or I would have chose someone new. Lots of good choices here.
So many sick trucks. But honestly... if there's ten trucks... and most of them have a dope suspension setup, armor, wheels and tires but only one has a built engine with a custom supercharger setup; well, it's kind of a no-brainer for me. No offense to anyone. Love all the trucks. But anyone can throw all those parts on, I know... because that's what's on my truck. So, it's hard to be impressed until someone starts re-building something that no one else is and has no clear direction to complete the project. Or even a guarantee that it will work at all. That's why I give Andrew props for his VK56 swap... and the 350 short block swap. Exploring a new frontier at that time. Good work out there though, way to be creative.
I'm going to have to think on this one for a few days too :D
Good luck and happy holidays to all :)
Voted!
