VK56 Swap/Complete titan swap
32076 Views 42 Replies 18 Participants Last post by  Skilander
5
Username:Skilander
Year:2006
Make:Nissan
Model:Frontier
Trim:SE 4x4
Color:Charcoal Grey
Mods:
Titan powertrain & running gear
Interior:
Exterior:
Drivetrain:
Engine: VK56 V8
Front: M205
Rear: M226 Dana 44
Suspension & Tires:
Radflo 2.5 coilovers
Titan swap
17" Black Rhino El Cajon w/ Mastercraft Courser MXT
Armor:
Stock
Performance:
Stock VK
PRG Engine and Trans mounts
Gear and Other:
Stock
In Progress:
PRG/Deaver 10 leaf race spring pack
PRG M226 Diff Cover
Rough Country Traction Bar w Upgrade
PRG SAW Titan Swap Kit
PRG Boxed Titan Lower A-arms
Radflo Titan 2.0 Remote Reservoir Rear Shocks
Catisrophic failure of the front driveline broke a hole into the side of the transmission, local salvage wanted between 2000-2300$.
Auto part Fuel line Engine Pipe
So I did some reading and bought a Titan instead.
This was its sad state when I picked it up:
Land vehicle Vehicle Car Tire Automotive tire
Land vehicle Vehicle Car Motor vehicle Tire
I was able to get the three flats to take and hold air again which was a big surprise. Also pulled the busted windshield
Land vehicle Vehicle Car Motor vehicle Pickup truck
After I ensure all parts are in running condition I will start the powertrain tear down.
But so far..
Land vehicle Vehicle Car Automotive tire Automotive exterior
1 - 20 of 43 Posts
Pulled the intake plenum and found quite a lot of oil sitting on top of the valves.
http://i1070.photobucket.com/albums/u492/Skilander/KIMG0790_zpscca7n5at.jpg
Sucked the oil out and cleaned them up. Pulled the spark plugs and checked compression. Initially a little low, but primed the cylinders with a little marvel mystery oil and brought the compression up well above minimum standards.
http://i1070.photobucket.com/albums/u492/Skilander/KIMG0806_zpsrkvbkwit.jpg
Going to electric fans and no A/C so I'll be getting a custom serpentine belt to accommodate the new length tomorrow, also will putting all fresh fluids in and seeing if she'll drive.
curious why you arent doing ac? its a single size belt to connect everything and the ac lines literally bolt into the vk compressor. from there its 150-200$ at your local shop to have them charge it for you.
Probably a dumb excuse for most, but I just don't use it. I'm much more of a windows down kinda guy.
Put her back together enough to drive out of the shop and around the parking lot. Everything felt strong and responsive. Planning to leakdown test before I start the strip down of the chassis.
The "custom' Serpentine belt:
me too man, i was just curious.
get after the swap. looking good!
Subscribed
Very interested in the outcome of this. Please be as detailed as possible! This is something I wanna do in the future. Subd
Reactions: 1
I'm putting together a start to finish "how to" video as we speak!
Reactions: 1
Performed some more tests on the VK56 this weekend. Really want to ensure its in good condition before doing the swap.
Cylinder leak down test.
Auto part Fuel line Engine Vehicle Gauge
Passed with no problems
Block test.
Auto part Vehicle Car Engine Fuel line
Also no issue
But last test of the day I found a problem. Added some UV dye to the radiator and let it run for a few minutes. Checked the oil and it was pretty glowy. Head gasket in my future.
Got the Titan gutted and out of the shop
Land vehicle Vehicle Car Motor vehicle Transport
Land vehicle Vehicle Car Transport Tire
And Pick-n-Pull gave me 21 whole dollars for the body.
Vehicle Motor vehicle Car Asphalt Road surface
Finished the front end swap. Installed the front diff m205 and half shafts, rack and pinion, upper and lower control arms, wheel hub assembly's with the Titans bigger breaks and rotors, and having to use the stock Titan wheels because the lug pattern is different. Big bummer, I was wanting to keep my wheels.
Land vehicle Vehicle Car Motor vehicle Automotive tire
Land vehicle Vehicle Car Motor vehicle Automobile repair shop
Truck has to look all sad without its rear-end until I finish welding on the new leaf spring perches for the m226 to mount up correctly.
Vehicle Car Pickup truck Motor vehicle Tire
Got the Vk torn apart and cleaned up for the new gaskets, everything looked good after getting the grime off
Auto part Engine Automotive engine part Rocker cover
Auto part Factory Metal
Machine Auto part Toolroom Metal
Reassembled with all new gaskets, ready to go back in.
Engine Auto part Motor vehicle Automotive engine part Vehicle
Waiting on the lift to open up to get the rear in. Sent out my harness to SinisterFrontier06 for some Pro rewiring. Getting close enough I can taste it.
This is VERY cool!!! Thank you for including so much info!!
very cool build. Looking forward to seeing more of this.
Looks like it's going to be awesome. Hope it turns out that way.
Awesome! keep it going
cant wait to see it finished.... this is going to be bad a$$
1 - 20 of 43 Posts
