1 - 20 of 41 Posts
I need the wiring harness diagram for the titan engine harness so I can figure out how to splice it into mine. Any help or pointers would be greatly appreciated!
Banned
Your really doing the swap. Can you post up pics ??
Discussion Starter #4
Im not picking up the engine until next week. Im just trying to get all my crap together before hand. Thanks for the help guys. Ill make a build thread as soon as I get started
Banned
I cant wait. Hopefully you'll be able to actually finish it. Good luck
Well its my daily so I kinda gotta get it done in a weekend or a week at the most
dang dude, well... i hope everything goes smooth for you. and if you wouldn't mind, could you do a write up and take lots of pics?
Discussion Starter #8
Ill document the process as much as possible. Seems like the harness will be the biggest obstacle from what I see.
Banned
Are you 2wd or 4wd ???
Don't forget the trans since the frontiers will not bolt up directly. Then you may have a driveshaft issue. If you are 4x4 then you have a whole new issue to get all of that working correctly.
Lastly, what year frontier to you have, it will make a difference when you pick the motor and then which harness you need to go with.
Final thought, I sure home you are an auto to fit in your week swap timeline but the manual would be a lot of fun.
Good Luck and look up Andy's build thread on the same thing.
are you a 6 speed or a wuss-o-matic (j/k, kinda... ha)? are you a V-6 or a I-4?
oh... well i hope it all works out.
Have you thought about what exhaust system you going to use? By that I mean you will probably have to make a custom one.
What State are you located in? Maybe someone on here can help you turn a wrench if you needed it.
your deffinatly not gunna get this done in a weekend man....
Where are you getting the motor at? and trans?
When you are closer to the install date post it up. I will see what my schedule is and may be able to stop in (2.5hr drive each way).
Discussion Starter #20 (Edited)
I swapped my s14 in a day, but this may be alot more difficult since its kind of a first time ordeal for the average dude. Ill make a build thread as soon as I get all the pieces together
Will do man much appreciated
1 - 20 of 41 Posts
