My 2014 Frontier SV 6 cyl has a small valve cover leak. Not enough to even show up on the pavement but it is a $600 job which I do not have. Will this leak be of any harm if I keep an eye on it for a couple of months till I can afford the repair?
Is it a seep or a leak?My 2014 Frontier SV 6 cyl has a small valve cover leak. Not enough to even show up on the pavement but it is a $600 job which I do not have. Will this leak be of any harm if I keep an eye on it for a couple of months till I can afford the repair?
⬆ 👆This right here, that is what I did, removed intake plenum in order to access passenger side valve cover when I replaced spark plugs, it wasn't that difficult, you just need to take your time.What Milage are you at? Some folks replace the valve covers/ Gaskets at the same time they do their sparkplugs for the reason @Zedbra mentioned. Group all the overlapping labor together on the job.
And, As @RamTest mentioned, a seep and a leak are two different things. Every vehicle I ever owned had something seeping. Never dripped a drop on my driveway and or required almost no fluid to be added so I kept an eye on them and eventually sold the vehicle that way.
