1 - 20 of 48 Posts
Does anyone make a utilitrac High lift jack Mount ? I am looking for one and can't find it anywhere
NFabworks does. It's not on there site but they do make on.
E-mail them [email protected]
i just used cariage bolts welded to cut down plate washers and drilled a hole in one for a lock
I made these with Unistrut...
Mounted if front of the bed:
And set Hylift on brackets then used eye bolts to attach:
Final shot with shovel in place..
I did this, I wanted double shear the way I drive. Also can slide a full size shovel behind it, and use the jack as a tie point. The cleats still go on to the track to. Put one in a crew cab also, so they do fit, and since they are over the wheel well you do not loose bed space.
Welded some 1/2" bolts to 3" long 1/4" plates; locked with Masterlock.. the track'll tear out before the mount.
I talked to chris today He is gonna send me a quote but he said since he has such a low demand on off road parts they have been making parts for boats instead.
Can still make them for you guys, Will have 10 sets ready by mid. March.
Got any pics of what they look like? What price?
nice! how much?
nice I'm in! I'll PM for more info
PM sent also looking for a set. will I be able to mount the highlift and keep my vinyl bed cover on? looks like theres enough clearance but not sure based on pictures.
Hopefully my set will arrive by this weekend and I will install them immediatly (unless it snows again). I've got cover on my bed too, so once installed we will all know the answer to this question.
1 - 20 of 48 Posts
