Does Nissan not sell the Utili-track system separately????
I've looked all over their site and can only find the cleats..
Is there another system like core trax that works just as well?
Thanks before hand...
Mike...:goodjob::goodjob:
Discussion Starter #4 (Edited)
Thanks Fishy,
It is pretty confusing but I'd never had found them if you'd not pointed them out.. I'd looked on their site previously and never connected it with the floorboard...
Thanks.. Mike..
Hi Mr Mustard...
What does Home Depot have that would make it cheaper to install something for
tie downs???
Thanks Mike..
Just an FYI, you can only add the utilitrac to the floor of your bed and maybe the backside. The sides are a different shape and will require a more custom install for them to work.
Home Depot has some parts in the electrical section that will work. One is like a C-channel but more square shaped over the rectangular shape of the utilitrac channel. Then they have these spring nuts that will work in the channel. Basically go to Homies and check out their electrical section and you should see what we are talking about.
