1 - 3 of 3 Posts
Whats the differences between the aftermarket a-arms (except titans) for the 2nd gen frontys? The 3 arms all look a little different and i'm want to know how much differences there are in the total travel and performance for each of them
PRGs ($600) looks like the ball joint is set in the middle of the bar, same as stock except the arm is more elongated and fitted with a bump stop to reduce clanking and contact with the bucket
Calmini ($450) has a similar design but they designed their ball joint welded a about an inch lower, will this help accomplish more travel?
Finally the Total Chaos arms ($710) are beefier, have a different design (not entirely rounded off) and the ball joint appears to also be dropped slightly from stock
Any opinions from those who own any of these arms, or have purchased one arm only to replace it with a more superior arm?
Links for those to look at the arms:
D40 Upper Arms
PRG Products
Total Chaos Upper Control Arm Suspension System for 05+ Toyota Tacoma, 07+ FJ Cruiser & 03+ 4Runner
Discussion Starter #2
Bump
No-one has any opinion on any of these?
1 - 3 of 3 Posts
