Just curious how easy it really is to install the undercover 5020. I found the link below about it...
http://www.clubfrontier.org/forums/f10/undercover-tonneau-cover-questions-51471/
I was just wondering what to expect because the bed has factory spray on liner and there is a liner on top of the side rail. I was just curious if those (side rail liner) will get in the way.
Anything you've experienced as an issue would be great if you could explain what the issue was and how you corrected it.
Also if it matters it's a 2005 NISMO Crew Cab w/Utillitrack with lift kit.
Thanks
Thanks
