while working on a turbo 300zx i noticed the motor is almost the same as the one in my frontier other than the bore size (vg30e<vg33e) and some other minor things. This got me thinking of my next build... Ive done some research but there isnt a whole lot of info on this. I found one person who took all the turbo parts from the zx and bolted them up to a vg33 but they put this motor back into a z not a frontier, So i know its possible to get the motor running and everything. Im pretty sure they used the ecu for the 300zx not the vg33e and one of my questions is will the computer be able to handle the .3 larger displacement? And this is a cali truck so when i get this smogged the computer wouldn't match my vin# correct? could i use the ecu in my truck has already or would it not run correctly when it sees boost? How about a supercharged ecu with some sort of piggy back tuner.
Ive got about 90% of what i need figured out for this build except what to do for the ecu, so im just looking for some opinions on how i can keep this running in optimal a/f ranges etc. and keeping it legal in cali which is always a pain. this is not going to be a 500+hp truck i only plan on running about 8-10psi and maybe a small sidemount i/c
* would standalone be possible?
