have you check the battery?
ya voy a push start, but it's on a long level road with no one here to help, lol.I have full power (stereo, lights, etc.) .......I checked the fuse panel and all seems well, and the fusible links look alright as well as no burned out relays (nothing obvious).....any ideas?
also would check the battery but i did just that last week. plus with full stereo system capabilities, lights, horn, etc. etc., and having just started it....why would this be indicative of the battery? it would still try to crank, or at least click a little bit.like the previous post... check the battery, if you cant then take it to autozone and have it tested.
even considering the possibilities you mentioned, it wouldnt have started just fine when it did....the truck died less than 1/2 mile from my house, it couldn't have developed a bad cell or voltage drop enough to not even 'click' the starter in what.....41 seconds or so? plus the connections are good.low voltage, bad cell, loose connection, voltage drop......
how did you check your batt? also you realize that the accesories you mentioned don't put a load on the battery like the starter?also would check the battery but i did just that last week. plus with full stereo system capabilities, lights, horn, etc. etc., and having just started it....why would this be indicative of the battery? it would still try to crank, or at least click a little bit.
the stereo system in my truck isn't factory, therefore my stereo system wouldn't function properly without a good battery/alt combo. so my odometer display wouldn't function at all without a good battery? didn't realize that it would put a load on the battery either, being a small LCD display...how did you check your batt? also you realize that the accesories you mentioned don't put a load on the battery like the starter?
A master ase tech told me nissans are finicky when it comes to eletrical crap. If you battery is bad, or alternator is acting up it will cause the things you're describing.
Why dont you get a volt meter or power probe and start checking relays, and fuses? Also have you tried by passing the clutch interlock? have you checked the ign key cyl?
