@ssundet - Thank you for advising. Yes, I did get them with the added spacer in with the Bilstein boot, but then quickly tore them apart to remove the boot to better accommodate as-design stack height. The haste in removing was due to CBC at full droop. Now, I'd probably never stress full droop during normal driving conditions, but it wasn't right regardless.
Two thoughts after calling Koni NA and speaking with a technical rep :
-1st being lifespan is surely compromised without a protective boot, so I ordered an OEM equivalent from an SV trim Frontier, which if I deciphered drawings correctly, attaches to a single spacer/washer below the rubber seat for the spring. So, I'm hoping this set-up can accommodate protection without adversely affecting stack height.
-2nd being the ride wasn't what I was hoping for, leading me to believe either a) I incorrectly set the rebound speed to be too fast/harsh or b) this just isn't the set-up for me...
So, either way I'm disassembling the strut assemblies again to hopefully install protective boot/bellows & going over rebound settings again in hopes of slowing/softening ride quality.
When I re-do the assembly I'll try and remember to take measurements of the Koni strut.
