Swapping out my old, tired Bilsteins on a 2013 Pro-4X.
New Koni's didn't have an upper shaft/seal boot protection, so I'm using the blue boot from the Bilsteins. When I put it all together, the new assembly is about 3/4" taller than the OEM set-up. Pretty **** instruction with the Koni's to be honest, tough finding any supporting documentation...
I can just maneuver it into position, but I'm having trouble getting the lower strut bolt through and mounted because the assembly is that much taller. Getting the upper three nuts on and mostly tight, I can't swing the lower mount into place with full drop on control arms... I think the Bilstein boot could be the culprit, limiting how far I can send the top cap before the nut bottoms out on all the stacked hardware beneath it if that makes sense?
Anyone have any input here? Truck's up on stands now and I'm scratching my head. First time taking on a job like this, so cut me a bit of noobie slack!
Thanks all!
Thanks all!
