If they are the same as the ones that I have, you simply turn the black bolt/knob (about the size of a 50 cent coin) which tightens the base plate in the track. Just make sure it lines up with one of the grooves in the track - about every 30mm or so, otherwise it will work its way loose as soon as any pressure is put on it.
Cheers Moorie.
