I purchased an 03 crew cab last weekend and so far I love it. It only came with one factory key. So I looked in the manual and it said nothing about the key being a transponder key. I went to have it copied and they tested it to see if it was a transponder key and it is not. The book they had said it should be that it was not optional. So I had one key made for $3 and it works fine. The lady who made it told me it could ruin my electrical system if it is suppose to be a transponder key and I am not using one.
This does not make sense to me. My previous accord took a transponder key and I had a regular key made to keep in my wallet and it would not even let me start the car with it.
So I assume their book was wrong but I just wanted to clarify because I do not want to damage the truck.
Thanks
I doubt if it would start at all. The transponder has to send a signal to allow the engine to start. They must be thinking about other brands of vehicles that allow a non transponder key to start the engine and then shut off. Some people end up having it towed to the shop after that happens. A friend of mine had that happen with a Jeep Cherokee.
I have an 03 too and the first thing i thought was that a DIY key would not work. Well the key did and I have not had an issue. I have no idea why that is in the manual.
thanks guys. I figured a cheap key would work fine. I wanted to make sure before I got a few more copies made.
