1 - 3 of 3 Posts
I recently bought a 2004 Nissan Frontier 4*4 3.3liter. I am having a few issues with the transmission, front suspensions and filling the gas tank.
The truck will randomly change gears while driving on a flat road going around 35-40 mph. I have changed both the fluid and filter, adding some trans tune and double checking that the fluid at the right level. Is this a solenoid, computer or something else that could cause this?
While working on the front suspension I have changed the shocks and the idler arm but the truck still will easily bottom out when going over a bump at minimum speed. What could cause this?
The last thing at the moment is I think the gas tank vent. To fill the tank with gas I must pump the gas very slow or it will automatically stop the pump. I think it has to do with the air vent. I found one on the gas tank but not on the gas fill line like I thought it would be. Do I have to remove the gas tank to clean the vent?
Thanks for your help.
Congrats on the new truck. I think you'll enjoy it.
I'm not exactly knowledgeable on the first gens, however I do know you have a torsion bar front spring.
How many miles are on your truck?
The springs could be weak or just need adjusting.
The fuelLing issue is a common one on the 2nd gens also. I don't have the answer accept continue to fill slowly. I use the time to check my oil and washer fluid, clean my windows, empty my trash bag, etc....
Good luck
1 - 3 of 3 Posts
