Need some advice on transmission maintenance. My 02 has the 3.3 V6 and is 4WD. I was under the impression that since it has 90 000 miles and is 20 years old that I should pull the transmission pan, install a new filter and gasket, and then refill with new fluid. Not doing a flush. I was told just recently at a shop that they didn't recommend this because of various issues. I have actually done a drain and refill which made it shift smoother. The truck has no real problems and I don't want to cause any. Should I change the filter at this point?
Thanks
Thanks
