You have to be kidding me right?I'm 64 yrs old. I put 150K on my last 4x4 Nissan. I've never changed any car or truck differential fluid. It is for the life of the axle. All this service is for the dealer's income.
Automatic transmission, change it about 100K. Manual, forget it and make sure it is full once in a while. You risk contamination every time you fiddle with it.
Pop
Seriously, maintence intervals weren't created so the dealer can try to bend you over. Imagine how much better your truck would run with fluids that aren't burnt to hell.You have to be kidding me right?
The key to a long lasting vehicle is general maintance and if you neglect it, your vehicles quality will reflect it.
And this is why I don't buy used vehicles anymore especially if they are high mileage. The lack of general maintance is astronomical.I'm overwhelmed by all the tribologists on this board. I'm willing to bet my maintenance costs on the 90 HB w/ 150,000mi over 18 years was less than anyone here changing fluids with every full moon.
I had one snap ring come loose on the left front hub, cost $150 to replace the seal and repack a bearing. Replaced the expansion valve on the AC. Replaced the HP hose on the AC. Replaced one carrier bearing on the drive shaft. Replaced one thermostatic clutch on the rad. fan. Repaired clutch slave cy. 2 times (seals). Repainted one time.
Otherwise, just replaced oil and air filters, assessory and timing belts, antifreeze every 3 years, engine oil at 4K, brake pads, mufflers and tailpipe, etc.
New owner is still enjoying with no problems. It still has the original brake fluid, original transmission lube (manual), original diff lube (front and rear).
Can you match that?
PS: No engine noises, no oil consumption, no transmission or diff noises, no leaks. Driven on interstate on long trips, across plowed fields in lo 4X. Not petted, but not abused.
false. the reason you do a coolant flush is becuase rust builds up in the water then eats through your radiator. that is why they reccomend you get rid of that and put new coolant in. so your radiator doesnt blow up in your face on the highway. have fun with that. same basic ideas for the rest. includig tranny and diffs. does that mean you also never change your oil? is that lifetime?just like oil, coolant does burn off a little bit.I'm 64 yrs old. I put 150K on my last 4x4 Nissan. I've never changed any car or truck differential fluid. It is for the life of the axle. All this service is for the dealer's income.
Pop
Well, now that this thread has become a bit out of wack, I will throw this out there.I have an 01 ,and is there plug on the trans to drain the fluid..?
What about changing the trans filter..? Does it have one..?
I asked a buddy of mine that owns an AAMCO trans joint about changing trans fluid and filters..He pretty much said "if it aint broke,dont fix it"..
I have 205,000 miles on my fronty right now....
And this is why you are at 200k+ on the motor. If you didn't, the oil would break down and not allow proper lubrication to the moving components and they would wear and get play and etc....FYI...I change my motor oil & filter very 3000 miles religiously,and have since the day I bought it new..and do flush the radiator at least every other Winter.
Changed my water pump & timing belt at 155,000,and the belt was still in great shape.
read much?false. the reason you do a coolant flush is becuase rust builds up in the water then eats through your radiator. that is why they reccomend you get rid of that and put new coolant in. so your radiator doesnt blow up in your face on the highway. have fun with that. same basic ideas for the rest. includig tranny and diffs. does that mean you also never change your oil? is that lifetime?just like oil, coolant does burn off a little bit.
Okay, now I am a bit confuses and I bet others are too. You are now saying that you actually checked these fluids to see how their color was and then that determined if they needed to be changed? If so, then atleast you checked them instead of just blaintly neglecting them as it sounded like before. The only thing to remember thou is that the color isn't always a clear sign if the fluid is past its prime or not.Interesting comments, but I'll change any dirty oil or fluid when the additives are used up.
I plan on changing the tranny fluid in my 08 just about 80K, unless it gets dirty earlier. I'll change the antifreeze about every 3 -4 years, no flush. The oil gets changed every 3-4K, cause that's when it gets dirty.
Antifreeze will not cause rust unless the additives are gone, usually because bubba put dirty water in to "top off". Only add antifreeze mix. If you need to flush the tranny "to get the water out" you don't need maintenance, you need a major repair.
Change the dirty oil, watch the color of the brake fluid(keep it sealed), use the Nissan filter, change the air filter every year or so, check the tranny fluid and diff fluids. Then drive it. If something goes wrong, it won't be service, just a bad part. Changing fluids never fixed a bad part.
