I'm selling my 05 Fronty and have my new 10 Frontier arriving in a few days. I've returned my 05 back to stock. What do I need to do in order to be able to use my CORTEX on my new truck?
if you put the other truck back to stock you should be good to go i believe
I guess I'm asking is what do I need to do with the new Fronty. Do I just plug it in and wait for the cues?
never used a superchips personally but that should be all you have to do, hopefully someone familiar with sc will chime in for ya
If you set you other truck back completely to stock, all you need to do is plug it in and do what the screen says. It shouldn't be any different from your 05.
Dan
I know the others said that you have to return the tune to stock but you also need to make sure no other selections are made as in timing advance and other crap.
I would also venture to say that you may need to update the programming on the programmer to ensure that it covers your new 2010 model. There were some issues with the programmers in the beginning on causing lock-up due to ecu differences/codes.
