1 - 20 of 23 Posts
Hey Hey! time for a mod.!:willy_nilly:
After seeing Idleone's Volt gauge install I've been itch'n to stuff something in that hole. :)
A transmission temp. guage would be nice next to my locker switch..
So I found this over at the Titan boards.
HOW TO: Install B&M Transmission Temp Gauge Kit - Nissan Titan Forum
I'm gonna run to my local speedshop and grab one and try it this afternoon.... any opinions?
Add/edit: Here's some additional info esp. regarding the threads..
http://www.clubfrontier.org/forums/f11/update-transmission-temperature-gauge-tech-info-60175/
He is going to put it where the blank is located since he doesn't have a 4x4.
I have been looking at doing the same thing. Just let us know how it goes.
Discussion Starter #5
Just to give you a bit more info, I believe SuperChargerSandy's husband, KRH2 did this mod also.
I believe he has a thread on TT and CT about it where he stated where he found the correct thread for the trans temp gauge. I remember seeing it on CT so it might be worth a quick check.
Why not get in on the A-pillar group buy?
Doesn't make since to look down to see your gauges.
Discussion Starter #10
Finished..
Well, preeety simple... sorta...:willy_nilly:
The plug/port in question. Plug wasn't very tight too.
When I stuck an allen wrench in the port, there was a "blockage" way in there; the sensor was likley too long.
The plug compared to sensor.
Decided to chop the adapter that came with the kit and fab a jam-nut. Didn't feel like going to the hardware store; a thick nylon washer shoulda worked(i think).
I was eyeballin' how far the allen wrench went.
Put an O-ring on with some Loctite and screwed sensor in
Ran the wire up into the firewall near the cabin filter. The route was very close to the Cadillac converter :laugh: so I used a section of high heat silcone sleeve to protect it.
Finshed install.
Simple yet effective.
Did you need a special adapter for the sensor or was there one included in the kit?
Discussion Starter #12
naw.. the sensor itself just threaded in; the 1/8" to 3/8" adapter got chop saw'd anyway :laugh:
been checking to seepage/leaking.. nope! the original plug really wasn't even that tight(snug + 1/4) so I don't expect any issues with the BIG sealing surface from the "nut".
Direct pic link for everybody:
Looks good there.
where is the switch blank from? is that stock? i want to mount more lights, and my switches like that
I did the same, but used the Autometer version. The senders must be a little different because mine screwed right into the test port and no fabrication was needed. The thread is 1/8" NPT
Discussion Starter #16 (Edited)
^the pic. shows an Autometer? 90* sweep...
The sensors are different for full sweep gauges
_ <- full sweep the tip diameter is smaller.
_ <- 90* sweep
Full sweep guages are way more $$ than 90s; for other "info" I prefer a full dial.
Anyway, I didn't like puttin' it in/on there w/o knowing what my "probe" pressed against in there.
add/edit: for all I know it coulda been a left over casting lip.
UPDATE:
Well, it's been about a hundred miles and all is well, Temps. sway pretty good so I've concluded that the "port" location is fine.
150* loafing along the freeway, 170-185* varying speeds, 180-210* load(uphill in OD)/abuse(brake stand). I haven't towed anything soo.. ?
.. the tip diameter is smaller.
Reading Comprehension owns me. I saw the first post and though you did the B&M one.
Finshed install.
That's the front brake pressure port according to the service manual. The torque is 65 in-lb.
I'v been looking into a trans temp and a read diff. temp guage. is everything still working good since you put yours in?
wow. great job!
that gives me some ideas.
1 - 20 of 23 Posts
