1 - 2 of 2 Posts
My 07' has 64,000 miles on it and I wanted to change out the differential oils, transfer case and do a drain and fill on the trans. My plan was to do 4 drain and fills over 10,000 miles and to change the filter on the first one. Well I pulled the pan off and when I was un bolting the filter there were 3 studs with a nut on them with the rest being hex head bolts. One of the studs sticking out turns instead of nut turning. How do I get that nut to break loose ? the other 2 studs broke loose and as far as I could tell there is nothing holding the other end,but they did tighten back up. Thanks for the help!
David
The filter does not get changed, even by the dealer. Close it back up and just replace the fluid.
1 - 2 of 2 Posts
