so there have been quite a few issues with the trans fluid and radiator fluid mixing on the nissan boards for the 05+ , which ends up killing the transmission
a while ago i bypassed the radiator and installed a new cooler with a fan , then did a drain and fill but since it warmed up the fan seemed to be running all the time (has an inline t-stat 180 on 160 off).
so i decided to get a larger cooler and come to find out a drain and fill is useless because the fluid looked like crap
well after 14qts later got clean fluid running thru the system and temps are alot better , also shifts tons better
2nd to last pic you can see the old cooler i installed , also temps were running 180-200 at the same ambients temps and same drive
sitting idle for about 30 minutes , one is in celsuis
after running for 30 minutes idle and 10 miles with 0D off
and here is what the fluid looked like only 2k after a drain and fill
