It looks like pin 51, and or 38 it appears to run through the electric brake pre wiring.Hey, wj, did u ever figure out why your BCM output pin 52 was staying hot all the time??
Not yet I'm off for a week starting next Monday. I plan to get it sorted out then. Got a bcm, and another relay kit just to have spares.?? According to the schematic you sent me, BCM pin 38 must be hot as it is fed from BATT thru a 10A fuse.
Pin 51 drives the right side turn relay, while pin 52 drives the left side turn relay. Since the Left side turn relay
never turns off, we might think that the BCM has a bad output gong to that pin. Did you change it out yet?
Lol it’s just my name.BLtheP, (wish that was decoded), I was a bit disappointed that there was never follow-up from the OP. I thought that we had just about trouble-shot down to the BCM; the OP said he would replace it; then nothing
. All the relay discussion, while interesting, seemed quite irrelevant to the problem; at least until the BCM was eliminated. Oh well. But Thanks very much for the insight on the relay harness!
As I mentioned above....the third relay won't make a difference on the auto. It's unnecessary but not hurting anything. The third relay is reverse for manual transmissions. If you have an automatic, then nothing will correspond to the wiring that the third relay hooks up to, so it's basically just a dead relay plugged in behind the panel.I think the issue was what I posted in the #66 post. Automatic tranny's do not need all 3 relays. I plan to revisit the issue in the spring. I'm not towing anything right now.
I know what it says. I had an auto trans truck for nearly two years and left my relay 3 plugged in despite what the instructions said. It's not a problem. Trailer tow diagram makes it pretty simple to understand too. The third relay is literally just for the backup lamp circuit, manual trans needs it and auto trans doesn't. It's not going to cause problems either way.The schematic in post #66 is from Nissan's site. It says do not use relay #3 for automatic transmission.
I missed where you said they went back to normal. So as soon as you unplugged the relay harness the left turn/brake started working properly again? Maybe there's something funky with that aftermarket harness you used. I dunno but that makes no sense. Maybe somehow the 3rd relay was backfeeding the circuit, I don't know. They should have nothing in common at all, but if it starts behaving when you unplugged that harness, then I guess maybe there is something there causing problems after all.But why would the trailer light function return to normal after I removed the relay kit?
