That's the kit I bought it's my understanding that to work correctly it needs a 3 wire to 2 wire converter. Also I can't remember which the automatic, or manual tranny doesn't require the brown relay that goes behind the kick panel. As to why I'm not sure.there’s three relays in the passenger side kick panel, two blue one brown, not really sure what they do, probably lights and power or something. Then there’s a wiring harness that connects to the plugs on your truck in the back (under the bed) and gives you a 7 (or 4) pin trailer connector.
There’s kits you can buy on etrailer or just amazon that include all the parts and instructions.
Your over thinking this. You need the relay wire set plugged into the kick panel. 3 relays on a pigtail. Doesn't matter AT or MT. Just plug it in. Then in the back there are 2 covered plugs. If you use a 4 pin you only use one of the plugs with the connector pictured below. If 7 pin, then you'll use both plugs.That's the kit I bought it's my understanding that to work correctly it needs a 3 wire to 2 wire converter. Also I can't remember which the automatic, or manual tranny doesn't require the brown relay that goes behind the kick panel. As to why I'm not sure.
You are right Jameson over at etrailer confirmed the t-1 requires no converter.Your over thinking this. You need the relay wire set plugged into the kick panel. 3 relays on a pigtail. Doesn't matter AT or MT. Just plug it in. Then in the back there are 2 covered plugs. If you use a 4 pin you only use one of the plugs with the connector pictured below. If 7 pin, then you'll use both plugs.
It's a flat 4 not sure on that one it was wired for over a year before this started.It's just possible that this is symptomatic of the famous "crossed wiring syndrome" in the small plug. See the sticky in Towing Forum.
Yes, and it won't blink/ flash either the other side work's normal.Looks like bright, too. So will it ever blink? I mean, there's no 12v hot wire in the 4-flat plug, so it's coming on the left directional signal wire, right??
Me either I swapped the under hood relays, and the ones behind the kick panel. Still nadaYou can get a new set of relays from trailer if they're not ok... I just don't know the circuit well enough to troubleshoot ...
