I just picked up a Big Tex 60CH open trailer this week. It uses a 6way round plug.
I bought the necessary adapter that inserts into my Frontier's oem 7 way plug and allows me to plug the trailer's 6 way wiring plug.
When I plug the 3 wiring components together here is what I get:
* (GOOD) brake lights on the trailer work properly when the brakes are applied on the truck
* (GOOD) both left and right turn signals on the trailer work correctly when the stalk on the steering column is moved up or down.
* (BAD) the electric brakes on the trailer lock so tight that it is impossible to move/pull the trailer without literally dragging it with the wheels locked. The electric brakes are applied on the trailer, regardless if the brakes on the truck are being used or not.
Regarding the runaway trailer brake system....
* The plunger that senses when the trailer has come loose is still intact
* I presume the battery is dead since its been sitting for so long
(FWIW: I do not have a brake controller on the truck)
When you unplug the trailer wiring from the truck, the electric brakes are deactivated and the trailer will move freely (like normal).
Any ideas why the those electric brakes are erroneously being activated and how I can get them to work correctly?
TIA
TIA
