1 - 4 of 4 Posts
· Super Moderator
Under the main covering I'd think the wires are standard colors which designate what each is for.
Go to etrailer.com and give them a call.
That looks like the OEM connector on the back of the factory 7 pin connection. If you broke the factory connector as I did you'll have to either order a new tow harness adapter from the dealer for about $100 or so, OR cut that end off and wire in an aftermarket 7 pin connection.
I chose the 2nd route are the factory connector is crap and mounted in a poor location.
How to with pinouts:
http://www.clubfrontier.org/forums/...market-7-pin-trailer-plug-256129/#post3139153
1 - 4 of 4 Posts
