Everyone,
As some of you may have seen, I recently purchased a used LEER Cap/Topper for my truck. I am in the process of figuring out the 3rd brake light and some interior leds.
My truck came w/ an OEM hitch and a 7-pin Harness (w/ relays). I would like to tie-in a piggyback harness between the Truck's pre-wiring and the Hitch's 7-Pin Harness wiring. This way I can pull the brake signal and 12v for interior LEDs (w/ fuse and switch).
To do this, I would need another set of connectors, both the Nissan Truck side and the 7-pin Harness side.
Does anyone know where I would get these other then seeing if a junkyard has a truck that I can cut them off of?
I am looking for a cost effective solution, not a buy new and cut-up solution.
Thank You
Thank You
