Replacing the 7-way harness on my truck. Harness is connected as per attached image.
Tested wires with my 12v test light and most are working correctly but...
I am getting a ground signal from both the Brown and White wires.
The White should be the ground and the Brown should be my tail lights.
Does this mean there is a short in the Brown (tail lights) wire?
Where would this wire be coming from? A fuse somewhere or just tapped into the truck's tail lights?
Not sure if it's the factory tow package or an aftermarket install... I do have a brake controller which is working.
Read a bunch of threads but it starts getting confusing when it comes to relays, kick panels, multiple fuse boxes, etc.
