I had a short in my trailer. I had no brake or turn signals working on the trailer (only running lights worked). After fixing the trailer short, I discovered the BCM (Body Control Module), Trailer Tow fuse (#60 in the engine compartment relay box) was blown-15A. I replaced it and now the turn signal trailer lights work but no brake lights. I checked trailer tow fuses in the engine compartment fuse box number 1 (fuses 32 and 38) and the stop lamp relay, stop lamp switch in the passenger compartment fuse box (#20)with an ammeter. They checked fine. The turn and brake lights work fine on the truck with the trailer attached or unattached.
Have I missed a fuse? Any ideas what could be causing the trailer brake lights to not work?
I've tried to read the discussions on this subject but have not found and answer.
Thanks, Bill
Thanks, Bill
