1 - 12 of 12 Posts
First off I want to state that I live in Canada, where TPMS is not federally mandated. Secondly it is my understanding of US Law that it is not okay for a shop to defeat a safety item, but it is okay for an individual.
Now I find the factory TPMS system in the Frontiers to be finicky and annoying. I would love a system that worked and was useful, but what we have is neither. If I do figure out a good way to delete or bypass the factory system, I will be installing a better aftermarket solution, that can read more than 4 tires, and tell you the pressure of the tire.
I came across a thread on a tundra site that mentions splicing a wire from the TPMS control module into a wire of the ECM to trick the ECM into thinking that everything is good in the TPMS world. Should work on out trucks as well as you need to use the OBD2 port when working with out TPMS. So does anyone know what wire that is on our trucks and where the TPMS box is?
Quoted from the Tundrasolutions thread
"I have an '07 Tundra, and I know there are a lot of solutions out there to disable the TPMS light, but I think that I have found a way to trick the computer into believing that everything is working correctly without removing the dash or having to store those stupid sensors in pressurized container in the truck. I bought $5 worth of stuff at Radio Shack and it took me about 30 minutes.
I soldered a 12 volt Zener diode, a 1/4 watt 2.2k ohm resister and a 1/4 watt 1k ohm resister together to look like this. Be careful with the diode to ensure that it is facing the correct way because it only lets the voltage flow one direction.
Behind the glove box is a small grey box with a 12 pin connector to it. You can do this mod without removing the glove box if you don't mind spending some time on your back in the floorboard.
Remove that connector and then on the left side of the connector (the side with the clip) remove the light blue wire (5th one from the top). There is a compression fitting on the side of the connector that you will have to pop out approximately 1mm and then you can use a pin to remove that metal connector out of the plastic harness from the connection side. This is fairly simple to accomplish (hard to explain) but only necessary if you think that you may want to return it to factory operation at some time, otherwise you can clip the light blue wire.
Next step is to connect the resistor end of the series that you soldered together to the light blue wire. Then reconnect the plastic connector to the computer and stick the diode end into the back of the plastic connector so it makes contact with the yellow wire in the top right position.
This sends approximately 4.4 volts from the computer thru the light blue wire to the combination meter to tell the system that there is no fault."
Make a small PVC canister and install 4 sensors and a valve stem. Pump it to 35#. Learn the sensors and throw it under your seat.
That system does not alway work. If you get a bad sensor, which the nissans are prone to no good. I am currently running the spare in my rotation so the truck still has the other 4 sensors but it is throwing a code because they are not turning. I feel the best way is to disable the system just need to find the wiring diagrams and play around.
Wheels don't need to turn for TPMS to operate. If they did, you'd be alerting at every light. There's no inertia sensor in there, it's a simple pressure switch and RF transmitter...
If by "TPMS box," you mean the control unit, it is built into the BCM. As far as vehicle owners in the US disabling the TPMS system, it is still not legal.
This was my understanding as well. It's a permanent subsystem. You can disable the LED in the dash, create a canister, or use some good ole electric tape over the bulb.
I have to disagree. It's sole purpose is to light up a bulb in the cluster if one of the tires is below the tire pressure threshold... and it does just that. In fact 4 days ago my light went on, reminding me that I haven't checked my tire pressures lately, and sure enough - 2 of them were low enough to trigger the light. Nothing "finicky and annoying", and it was 100% useful because it did its job as described.
Our trucks have the distinction of being one of few that centralize many things through a main BCM - including the TPMS system.
Looks like poster's biggest problem is he's trying to use a toyota tundra fix on a nissan frontier.
Yeah nice try, but doesn't work that way.
I'm kind of wondering what the point would be. All the TPMS does is turn on the "idiot light" on the dash. Unless a safety or emissions inspection requires that the light not be lit in order for you to legally drive, if the system is malfunctioning such that it lights the light when it shouldn't, and you don't want to spend the money to fix it, you can ignore the light, or if it really annoys you tape over it or remove the bulb or LED for the light.
On my Frontier, which is still fairly new, the system has functioned as it should. It alerted me to low pressure when I had a puncture, and has lit the light a few times when it was very cold, and turned off after it warmed up (I didn't add air on those occasions). Personally, I probably wouldn't spend any money beyond new sensors to fix it if it failed, as I managed pretty well without the system for my whole life. A system that actually displays tire pressures, as I have seen on other vehicles, would be more useful. It would also be nice if it worked for the spare.
On certain models, it does show the tire pressures, like on my 2008 Pathfinder. However, it wasn't the case on my 2006 Pathfinder LE non-navi and apparently not for the Frontiers. On the 2008, you have to work thru the menu to get to the air pressure monitoring screen, but at least it's available. Hopefully, they'll make that feature standard on the 3rd Gen. The system, itself, is pretty reliable with the single, common failure of dead sensor batteries. Better battery technology (in making longer lasting batteries), or at least replaceable sensor batteries, would improve the system, as well. It's alerted me on two occasions to low pressure caused by nails in the tires and I do check my tires pressures regularly.
1 - 12 of 12 Posts
