21 - 21 of 21 Posts
I did the firestone ones. Pretty easy I guess, though you have to loosen the axle bolts to remove the bump stops. I flipped the carriage bolts around so they went top down and I had to square up the round holes so they'd fit.
The push to fit fittings get a thumbs down from me and I prefer 1/4" compression fittings as they will seal against nicked lines and the push ones will leak. Though I think I still have the push to fit elbows on the bags, I did get rid of the rest as I spent tooo many hours chasing leaks. If you just do the basic bags with fittings by the license plate then you'll probably be fine. I installed a pump and dump valves and a gauge inside the cab so I dealt with more connections.
21 - 21 of 21 Posts
