1 - 11 of 11 Posts
Ok so i did the 3 and 2.5" leveling kit about 8 months ago. When towing my 20ft boat that weighs around 3000 it makes the truck hard to handle. Like it almost looks like your drunk driving if you are behind me and following me. Any help or suggestions on what i need to do to fix this and how much will it cost? Websites on where to get the parts etc....
Its called sway, and you likely have too much tongue weight, or you didn't buy a drop hitch to level out your trailer after the lift. It should ride level or angled slightly downward. If the tongue is angled up you will get sway.
I was just going to say the same thing. I pull a 20ft Pontoon, about 23 ft overall with tongue and outboard motor and have zero issues (stock height 4x4). Thinking you need to re-level the trailer. Can you take a photo and upload it so we can see your setup? Raising the truck shouldn't effect it that drastically.
Too little tongue weight will cause sway as well. In fact, towing butt heavy is *more* likely to cause sway...
https://youtu.be/4jk9H5AB4lM
IMO the axle on that "trailer" is badly placed, probably to heighten the demo effect, but this is a good example.
I have a 2.5"/1.5" Leveling kit and 33's and I have to run 5-3/4" of drop on my hitch shank for normal, non-lifted trailers.
Which is actually a plus, since I couldn't open my tailgate when hooked to my popup before I lifted truck/dropped hitch. The extra bit of drop pulled the ball an inch away from the bumper. It's a tight squeeze, but it opens.
1 - 11 of 11 Posts
