1 - 10 of 10 Posts
My 2019 SV Crew Cab did not come with the tow/haul feature. I plan to get a small camper (4000 lbs). Would it be a good idea to install this feature or just manual shift when I need to?
2021 Frontier SV CC 4x4; 2018 Frontier SV KC 4x2
There’s no tow/haul feature to add, assuming you already have a hitch & trailer wiring. Just turn off O/D.
2012 CC "S" 4x4
I have a 20' 4000lbs camper, when I tow, I put truck in D and go, I manually shift to a lower gear on steep downgrades if needed, never had any problems in 5 years. And I leave the overdrive ON
The manual says to turn off O/D, but admittedly I rarely follow that advice either. Both of my Frontiers handle towing loads pretty well without too much human intervention.
2019 Nissan Frontier Pro-4X
The 2nd gen Frontiers don't have a tow mode. You're suppose to turn the O/D off by pressing the button on the shifter. Obviously, if you're going down a steep hill, then it would be a good idea to manually shift down. Use some engine braking to keep the trailer from pushing you around.
2012 CC "S" 4x4
I have heard that, but I can't find anywhere in my manual that says that, maybe cause my truck is older? IDK
Maybe so. It’s in the manual for my ‘18. The manual for my ‘21 doesn’t mention anything like that.
2012 CC "S" 4x4
that's pretty interesting:confused: I went Nissanusa to look at the towing guide, but they only go back to 2013
2022 Frontier SV 4X4
It really depends on how the truck is handling the load. with my 2007, I used to tow empty and light trailers without canceling the O/D but heavier loads I would turn it off. What I had been told, the main reason is to prevent the transmission from cycling the O/D on and off under heavy load. I experimented with mine a few times and did notice on slight hills it would immediately shift out of O/D so i can see this preventing wear/tear on the transmission, as well as keeping the stress lower on the overdriven gears. You already take a hit on fuel mileage towing so the O/D isn't going to make a whole lot of difference.
2019 Pro-4X (30,000km)
2019 PRO-4X. In my experience and towing without O/D off (at highway speeds) would result in the transmission doing a lot more searching/shifting resulting in transmission temperatures, particularly in the torque converter, rising quickly. Less pronounced with O/D off. Less of an issue when city driving, variable speeds etc.
1 - 10 of 10 Posts
