1 - 11 of 11 Posts
Hi All - Can anyone tell me what the proper torque values are for:
Caliper Bolts:
Caliper anchor bolts:
Lug Nut:
Many thanks guys :)
Uhhh, which year and what trim?
Also, there is a sticky in which has the FSM that you can download. It may be your best thing to do so you have all TQ specs and "how-tos".
Caliper Bolt- 32 Ft lbs
Caliper Anchor Bolts? Are you referring to the bolt that has a rubber piece holding the actual brake pads? it has internal threads.
Wheel Lug- 98 Ft lbs
The caliper anchor bolt holds on the anchor plate I believe. What I am doing is replacing the pads and rotors so i want to make sure everything is torqued properly.
Dubie2003: Where would I find that download?
Appreciate any help.. thanks
Hello and thanks for the input. I am a little confused - I have two different people saying two different values for the torque specs on the caliper bolts / caliper anchor bolts. Does anyone know the true specs?
Thank you again, this would really help me this weekend..
Thanks - I went through that entire manual, I cannot find the Torque values.. Am I missing something?
1 - 11 of 11 Posts
